So everything was compatible until i changed to a pc case i really liked but then i got this note,
  • The Raidmax Vortex ATX Mid Tower Case supports video cards up to 390mm long, but video cards over 300mm may block drive bays. Since the Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card is 310mm long, some drive bays may not be usable.
Should this be in issue?
https://linustechtips.com/topic/371101-question-about-my-build/
It depends on how many storage drives you want to install.  That message means that the GPU will interfere with some of the drive cages, meaning that you will have to remove the drive cages.
https://linustechtips.com/topic/371101-question-about-my-build/#findComment-5024121
