Capacitor repair?
Go to solution Solved by FruitBasketSilex,
Dunno, its been 6 months so I would assume no
I would assume otherwise. Try calling gigabyte.
Hi, Ive got a Gigabyte 970A DS3P and Ive had some trouble. A few months ago, I had a capacitor fall off, so I put it back on. It happened today, so I tried to put it back on. This time, the pin broke. I cant very well put that on, so can I repair this or pull warranty? I dont know how long warranty is, or if it even covers this. Any help is appreciated.
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
https://linustechtips.com/topic/370526-capacitor-repair/
Can't you just deal with the retailer who sold it to you?
https://linustechtips.com/topic/370526-capacitor-repair/#findComment-5017045
Is it within the RMA period?
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/370526-capacitor-repair/#findComment-5017072
I would, but I never registered when I bought it (December)
https://linustechtips.com/topic/370526-capacitor-repair/#findComment-5017083
https://linustechtips.com/topic/370526-capacitor-repair/#findComment-5017095
https://linustechtips.com/topic/370526-capacitor-repair/#findComment-5017098
AFAIK most boards come with a limited 3 year warranty.  I'd definitely call the manufacturer.
Xeon E3-1241 @3.9GHz, 1.07V | Asus Z97-E/USB 3.1 | G.Skill Ripjaws X 8GB (2x4GB) DDR3-1600 | MSI RX 480 Gaming X 4GB @1350MHz/2150MHz, 1.09V/.975V | Crucial MX100 256GB | WD Blue 1TB 7200RPM | EVGA 750W G2 80+ Gold | CM Hyper 212+ w/ Noctua F12 | Phanteks Enthoo Pro M | Windows 10 Retail
https://linustechtips.com/topic/370526-capacitor-repair/#findComment-5017122
Definitely go warranty if you can.
If you cannot then which kind of cap is it?  Is it SMD, or is it through-hole with leads?   Either way getting a replacement should not be a problem from somewhere like Mouser.com but attaching it might not be real easy.  Most production soldering today is high temperature lead free.  You can't just reflow it, or drop a blob of lead-tin on top and expect it to work.
If it has leads then protecting nearby components with heat sinks, and using a high watt pencil should take off the old stuff, allowing you to attach the replacement.  If it is surface mount it is still possible but you are going to need a quality soldering station and a very fine soldering tip.
https://linustechtips.com/topic/370526-capacitor-repair/#findComment-5017335
