So me and my girlfriend have started playing split screen games. As a lot of you know console has always beat PC in local multiplayer so what better way than to get console on my PC :D
I saw a program called Launch Pad or such that is kind of a main ground.
Where would I obtain all the files needed for emulator, what emulators, what do I need to set up to play split screen with 2 controllers, what games do you recommend (getting Mario Kart Wii as an essential xD) and how do I set up Launch Pad / Download Launch Pad?
Thanks guyz! :D
https://linustechtips.com/topic/370522-emulator-help/
You just need the emulator to play split screen games.Like dolphin for Wii has option to configure pad 1,2,3 and 4 with keyboards or controllers.
2500k 4.0ghz,GTX 1070 oc,MSI Z77A-GD55,G.SKILL Ripjaws(4 x 2GB)DDR3 1333,OCZ Arc 100 240gb,Samsung Spinpoint F3 1TB,Corsair TX 750w v1,CoolerMaster HAF 912,Hyper 212 EVO
https://linustechtips.com/topic/370522-emulator-help/#findComment-5016945
Is this a re-post as I'm pretty sure I already commented on this exact post? Never heard of this Launchpad but you certainly can't go wrong with Dolphin I use it all the time and it's fantastic especially for 3D gaming, Wind Waker in 3D is pretty nuts.
There are 10 types of people in the world: those who understand binary numbers and those who don’t
bulgara, oh nono
Multipass
https://linustechtips.com/topic/370522-emulator-help/#findComment-5016993
I made a similar post but it wasn't the same.
https://linustechtips.com/topic/370522-emulator-help/#findComment-5017005
:ph34r:
Okay so I have started playing split screen with my girlfriend but of course console has always supported it more often so I was thinking of like emulating mario kart or something but how would I do that split screen with 2 xbox 360 controllers?
Also there was a program someone suggested that is like a huge programs for loads of emulators and organised them, what is it?
bulgara, oh nono
Multipass
https://linustechtips.com/topic/370522-emulator-help/#findComment-5017015
:ph34r:
Kool m80 but if you saw I asked plenty more questions on this thread as I would like a larger variety of answers.
https://linustechtips.com/topic/370522-emulator-help/#findComment-5017041
Relax man I was joking I couldn't care less if you re-post or not although you will get a lot of people on here telling you off if they see it, Mod fanboys. They will probably tell you to just repost in the original post with updated question.
bulgara, oh nono
Multipass
https://linustechtips.com/topic/370522-emulator-help/#findComment-5017071
