Can u have 1eth cable. read topic
Go to solution Solved by Arty,
Can u use all devices at same time to get internet on?
yea
Like i have my router in the livung room i want a ethernet cable into my room and i have 4devices that i want ethernet cable in can i get 5 in 1cable so i dont have 5ethernet cables from my router?
yes
https://www.google.com/search?q=swtich&oq=swtich&aqs=chrome..69i57j0l5.863j0j7&sourceid=chrome&es_sm=122&ie=UTF-8#safe=off&q=switch+ethernet&spell=1
I dont want second router in bed room beside it
It's not a router it's a switch it's basically a splitter for ethernet cables in the most basic terms if you want more than one device connected to a single ethernet line you have coming in.
yes a switch will let you do that the limiting factor is the throughput of that single ethernet cable coming in to feed all those devices using it at the same time.
I have 4 pcs on a switch. Then I have 2 routers on the switch. The line in comes in from the modem/router.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
But do have to get specific cables switch? For diff mbs? Like i got ps3 laptop and getting gaming rig
It just depends on the cable you have incoming and the hardware as long as everything in your network to that room is gigabit throughput (1000mb/s) and if you want to maximize that throughput to your devices a gigabit 5 or 8 port switch will work well for that.
Is she switchers saying 10/1000mbs and stuff
Basically if you have gigabit ethernet connection coming into the room and want the best connections a 10/100/1000mb/s switch will provide the max throughput.
No 5-in-1 cables. You can use a Y splitter (and by a I mean 4), but this will decrease speeds to ~100mbps. Still uses more then 1 cable however.
Switch would be best...
Well how do gigabit internet like my internet speeds are 25down 5up ms is different evry time almost
It's not the speed of your internet that dictates the throughput capacity, the throughput is just the amount of data that can transfer through at once simple idea is pipe size.
Mainly a gigabit connection will never be saturated to full capacity in most situations.
Something like this will fit your needs and then some:
http://www.amazon.com/TP-LINK-TL-SG1008D-1000Mbps-Switching-Capacity/dp/B001EVGIYG/ref=sr_1_6?ie=UTF8&qid=1432191555&sr=8-6&
