Hello Everyone
I have this logitech bluetooth audio adapter and i'm very pleased with it in general. The only thing that really confuses me is that the "bluetooth audio" from my phone sounds way better than the "bluetooth audio" coming from my laptop. Is there an explanation and might there be some kind of fix for it?
https://linustechtips.com/topic/370405-bluetooth-audio/
Hello Everyone
What bluetooth software are you using on your PC to stream the audio? Check that it's indeed set to 'A2DP audio' instead of 'headset'. In headset mode, the bandwidth is divided between audio and mic, while in A2DP, all bandwidth is used for stereo channel audio.
Also I found the best software to be bluesoleil, in terms of stability, GUI, and simple to use.
https://linustechtips.com/topic/370405-bluetooth-audio/#findComment-5016185
