hello,
Well some time ago i bought the coolermaster nepton 240m and after 2 months of use the pump died so i send it back to get a replacement and today it arrived!!
After i installed it for some reason the pc wont boot !!! It does power on and everything is working pump lights , pc fans , mobo everything looks ok but there is no singal going on the monitor.
I tried reinstalling the stock cooler to see if there was another issue with the computer but with the stock cooler the pc is booting fine!!
Is there a chance this unite is also dead cause it looks like its working!!
Mobo:asus maximus vii hero
Cpu:intel i7 4790k
https://linustechtips.com/topic/370347-cm-nepton-240m-issue/
I don't know if this is possible but try using the stock heatsink and plug in the 240m at the sametime with it being on a desk not on the cpu see if it boots.
https://linustechtips.com/topic/370347-cm-nepton-240m-issue/#findComment-5014767
