Method Help with Ruby
Solved by flowalex,
Thank you for your help, I was talking with a classmate and they noticed I made a mistake in the method creation. Here is the code for future reference
#method creationdef to_array letter return letter.chars.to_aenddef get_permutations letter_array return letter_array.permutation.map(&:join)end#asking for user inputprint "Please enter a string of letters: "input_str = gets.chomp#opening the dictionarydictionary = File.open("dict.txt", "r") #assigning the arrayarray = to_array(input_str)#getting the permutationsperms = get_permutations(array)#while loop that compares the permutations with the unix dictionarywhile line = dictionary.gets perms.each do |perm| if line.chomp.downcase == perm.downcase print perm, "\n" exit end endend#closes the dictionary filedictionary.close
