How many fps?
I would like to know how many fps would I have playing battlefield (another demanding games). Ive checked the gtx970 and its benchmarks, but I want want to know how will the general build affect its fps. I wanna play at 1920x1080, I usually play BF(4 and hardline).
Note: I believe the builds wont need anything else (maybe an ssd or hssd), but to be sure, would I have to buy extra fans or something?
Thx
Also, would spending some more money in this build would be worth it? Is the difference too noticable?
- $886.93
- $816.99
General rule of thumb:
If you are gaming and doing light to no editing then the I5 4690k is perfect.
If you are doing heavy editing and gaming then get the i74790k.
I am guessing at 60+ fps on max settings since 1080p shouldn't be that demanding for this system.
