So I finished my build.
I have:
CPU: Intel Core i5-4690K
CPU Cooler: Cooler Master Hyper 212 Evo
RAM: DDR3 Corsair Vengeance Black 8GB (2x4GB) 1600MHz CL9 1.5V
HHD: Seagate Barracuda 3.5'' 1TB SATA3 7200RPM 64MB
SSD: Samsung Evo 840 250gb
GPU: MSI GeForce GTX 970 GAMING, 4GB GDDR5 (256 Bit), HDMI, 2xDVI, DP
Case: Corsair Carbide Series™ SPEC-03 RED LED Mid Tower Gaming
Motherboard: Gigabyte GA-Z97X-Gaming 3, Z97, DualDDR3-1600, SATA3,RAID, HDMI, DVI, D-Sub, ATX
PSU: Stil need :D
https://linustechtips.com/topic/369589-need-help-with-some-parts/
that ssd should be a 850
as for the other parts
a seasonic 600w
gigabyte z97 board...just depends on price
case doesn't really matter...corsair spec 03 is nice and cheap
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
make sure you apply the newest firmware on it then
I think I will get
And now I realized that I think I don't need GTX 980, I looked some reviews of 980 vs 970, And FPS difference is about 15fps~
p.s. I will have two monitors one 1080p for gaming and other with lower resolution for background stuff.
Do you plan to sli the 980?
Sorry I just edited my post
I picked:
And, no sli, maybe after few years I will just buy new gpu, I'm not planning to sli.
And I have question about RAM, will corsair be good? I see everyone is taking Kingston.
Now I just need PSU.
The brand of the ram doesn't matter. Get the cheapest set 1600Mhz and above, 1.5V and below, and preferably CL9 or lower.
As for the PSU, this is a decent unit:
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  (€49.49 @ Amazon Deutschland)
Total: €49.49
Generated by PCPartPicker 2015-05-19 19:12 CEST+0200
Never cheap out on the PSU. The CX series from Corsair use low quality capacitors which are subject to failure under load.
Total: €49.49
Maybe you know other good PSU, because I buy everything from one website (In my country) and they dont have XFX TS 650W
Anything that is 500W and above, tiers one through two from this list:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
So what do you think about those? :D
Corsair power supply RM 550W, 80PLUS GOLD, fully modular, ATX, 135mm fan (116 Eur)
Corsair power supply CS550M 550W modular 80 PLUS Gold ( 90EUR )
So what you think about those? :D
They're subpar in quality, not ideal for use in a gaming pc. They have cheap capacitors which can fail under high temperatures just like the CX series.
Maybe you can help me to pick from this site ( http://www.skytech.lt/kompiuteriu-komponentai-maitinimo-blokai-c-86_85_300.html )
Or say good brands to look for :/
