What is a safe operating temperature for a device like this? I was browsing through the app store and saw a cpu temp app. Temps were higher than I would of thought. Idle is in the 40s, Browsing I get about 50c-60c, CPU stress test brought it up to 79c, and zooming in and out alot in Clash of Clans  ;) got it as high as 88c. The device feels very hot in one area as well. Is this fine for a fanless device?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/369402-nexus-7-2013-cpu-temps/
I'm pretty sure it's not supposed to run that hot unless you're running a custom rom that doesn't throttle. Apple and nVidia target a max temperature of 45C, so you should aim for that O.o
A max of 45c is pretty low. I wouldn't compare to other companies.
https://linustechtips.com/topic/369402-nexus-7-2013-cpu-temps/#findComment-5001617
It shouldn't run hotter than that unless something is awfully wrong or it's not throttling properly.
I guess I wish I found out the temps sooner. I've had the device for almost 2 years.
https://linustechtips.com/topic/369402-nexus-7-2013-cpu-temps/#findComment-5001709
I am looking at this on my Nexus 7 2013....this shit is always hot.
My Nexus 7 has been cool as fark, even with room temps of 30c.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/369402-nexus-7-2013-cpu-temps/#findComment-5001757
