Hey guys. I'm in dire need of help. I play games like LoL and CS:GO. Sometimes in the middle of a game, my ping can skyrocket to 300-1000 ping. SOMETIMES* someone else can be streaming in the house but it isnt all the time. I just need some guidance on why im the only on in-game that is lagging and it might not even be my connection issue.,
Thank you in advance
https://linustechtips.com/topic/368486-ping-problems/
Looks like a router issue what's your router and you might can check to give your games priority over other traffic.
https://linustechtips.com/topic/368486-ping-problems/#findComment-4988249
Would ask my Dad cause he works for Time Warner Cable but hes in Turkey right now...
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/368486-ping-problems/#findComment-4988255
1) Use a WIFI analyzer to analyze all WIFI signals in your locations.
2) Choose a channel with the lease amount of traffic. (1, 3, 6, 8, 11)
3) Sometimes if your cable company uses a certain backbone method, if other people are using their internet heavily in your location your speeds will slow and latency will become noticable.
blackshades on
https://linustechtips.com/topic/368486-ping-problems/#findComment-4988313
Well we have a high end asus router, but we stopped using it, idk why. but still the router shouldnt be the problem? I feel like the information could be bottlenecking somewhere. I'm not positive tho. Thats why im asking ;)
U have a Highend and stop using it facepalm
No it must be either your router or the connection.
https://linustechtips.com/topic/368486-ping-problems/#findComment-4988394
Well i did a tracer in command prompt and my connection seems to be fine. even when streaming. There was no major ms issue during/not streaming. i connected to all the servers fine. So i cant see it being my connection or router
I was tracing it to the steam servers, so yea :/
https://linustechtips.com/topic/368486-ping-problems/#findComment-4988421
