First Gaming PC Build Help
Go to solution Solved by FrisoVDVeen,
Ok, thanks
if you have all the information you need dont forget to close the topic
I am looking to build my first gaming pc, and I have an overall budget of $1400 (including monitors, windows 8.1 etc.). I am looking for ugradability, and I want a geforce gpu. This is the build I put together: http://pcpartpicker.com/p/hZ96Vn Any thoughts, syggestions? Thanks!
https://linustechtips.com/topic/368364-first-gaming-pc-build-help/
Get an h97 board for an xeon.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Xeons are not really ment for gaming
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
From what I understand, they are equal to the 4770 when it comes to gaming, and slightly better for things like video editing. One disadvantage is you can't overclock, but being it is my first time anyways, I don't want to mess around with overclocking anyways.
Do I really need better/more ram for minor video editing and gaming? I probably can't run better than 1080p with a single 970 anyways.
well i had 8 GB of ram and then i upgraded to 16 GB of ram and i noticed the difference in games a lot the frame rate jumped up massivly and more ram is better for video editing as well and in games you cant use the 2nd monitor i have tried it myself
I know you can't use both monitors in games. It's more for productivity/multitasking.
i dont know but i think it will be good because of the frequency and the number of cores
Ok, thanks. I think I will stick with the 8gb ram and 2 monitors for now. Ram is such an easy upgrade that I would rather get the monitor sooner. I also will eventually upgrade to 2 970s in sli. That should last me for quite a while.
tip do not go to 3 970 the price to preformance is not worth it on 3 on 2 it is good
