@virtualTune or if you were to google maybe? "gpu rendering cinema 4d" would do the trick
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/367745-c4d-help/#findComment-4978696
im trying to render a sequence but i got the suggestion to change the rendering method to CPU instead of GPU, how can i change it?
there is no such option in C4D. Cinema only uses the CPU unless you use external renderers like Octane or Furryball
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/367745-c4d-help/#findComment-4986721
