Unexplained frame capping
Solved by Weak1ings,
Make sure of a few things.
Power saving settings
Single Display Performance (really helped me)
What kind of monitor do you have? 120hz+?
Check the Nvidia Control panel for Vsync global settings and for those specific games.
If your not maxing the GPU, try bumping up AA or something. That might work.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
