Hello guys ,
I'm from Egypt
I decided to build a new PC for gaming. i'm have no experience and i need your help
a friend picked up these for me
Intel Core I5-4690K
Gigabyte GA-Z97-D3H Socket 1150 Motherboard
Kingston HyperX Beast 8GB (2 x 4GB)
Western Digital (WD) Caviar BLUE WD10EZEX 1TB
Gigabyte GeForce GTX 970 G1 Gaming 4GB GDDR5 Windforce 3X
eaSonic S12II Bronze 520W 80 PLUS Certified PSU
Cooler Master HAF 912 Combat Mid Tower Desktop Case
ASUS 24X DVD-RW DL drive
i need you to check if something should be replaced or removed
and should i get ssd ???
https://linustechtips.com/topic/366542-first-build-need-your-help/
Thats a great build. 10/10, no changes. I would add an SSD only if you see fit. It wont affect overall performance, but will make loading snappy, so thats your choice.
“I don't like country music, but I don't mean to denigrate those who do. And for the people who like country music, denigrate means 'put down'.” - Bob Newhart
Remember kids; just because Linus has a video on it, doesn't mean that its the best choice Abide by the CoC | Looking for build help? Read this before posting |
Hello guys ,
I'm from Egypt
Intel Core I5-4690K
great build.
and yes. if you can get an ssd for the os / steam n all. its really worth it. makes everything run faster.
Looks good, It will handle almost anything you can throw at it, But id recommend getting a 550watts PSU, But a 520 should be enough.
Can you recommend a monitor and an SSD for me ???
A 128gb one that isnt a Kingston v300 should be good.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
Anything 1080p IPS from Acer, ASUS or BenQ
As for the SSD; Kingston, Corsair or SanDisk are all good. 128GB and up.
is this good monitor ?
BenQ DL2215 Full HD 21.5 inch LED MONITOR
Its TN, so maybe an IPS version..? The only reason for IPS is just viewing angles.
i'm sorry i don't know what that means
i don't know what ips or tn is
i find this too
Samsung S22B300B 22" LED Black
i will be so grateful to you if you pic a 22 inch monitor :)
i
i find this too
i
From a quick google search, this seems like a good monitor.
IPS stands for In-plane switching. It just means that as you move, and dont look directly at the image, there is no color shift.
TN is just a form of monitor that has color shift has you move.
Thank you very much sir
i'm really grateful for your help
Hello guys ,
I'm from Egypt
Intel Core I5-4690K
Hey there :)
As the guys suggested, a SSD would give you lots of benefits in terms of responsiveness and loading times.
Also the choice of the motherboard and the CPU indicate that you would be doing overclocking of the CPU. If so, you would need to get a custom CPU Cooler. If not, You can drop to a H97 type motherboard and a non-k version of the processor. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
Hey there :)
Captain_WD.
Thanks for the advice :)
i guess i will be overclocking the cpu . Can you recommend a custom CPU Cooler ?
Since I am a Western Digital representative, I cannot really recommend other products or brands. I could suggest looking around the forum for other recommendations, check out some reviews and ratings and see what would fit best in your budget. :)
Captain_WD.
