I have been saving up for a while now for my first actual pc and was wondering if you guys had any good ideas that would go with my budget. I only have about $1100 to buy the computer and 2 monitors. I'll just use my crapy old mouse and keyboard for now. And help will help so ya. Thanks guys
https://linustechtips.com/topic/366524-build-help/
Do you need an OS? If not...
Edit: Just read, Give me a moment
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($122.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card  ($273.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Monitor: Acer G227HQLbi 60Hz 21.5" Monitor  ($119.99 @ Amazon)
Total: $1130.45
Generated by PCPartPicker 2015-05-14 13:35 EDT-0400
Edit: With OS
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($88.99 @ SuperBiiz)
Memory: Pareema 8GB (1 x 8GB) DDR3-1600 Memory  ($47.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($86.88 @ OutletPC)
Total: $1135.53
Generated by PCPartPicker 2015-05-14 13:39 EDT-0400
Just install windows via USB
Edited by improbablepants
“I don't like country music, but I don't mean to denigrate those who do. And for the people who like country music, denigrate means 'put down'.” - Bob Newhart
Remember kids; just because Linus has a video on it, doesn't mean that its the best choice Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/366524-build-help/#findComment-4964252
I need a mix between both.
Yes I need an OS.
See my edit.
https://linustechtips.com/topic/366524-build-help/#findComment-4964295
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor  ($189.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card  ($253.98 @ Newegg)
Total: $1095.66
Generated by PCPartPicker 2015-05-14 14:00 EDT-0400
https://linustechtips.com/topic/366524-build-help/#findComment-4964422
Is it possible to add an ssd into that or not?
It is, but you would have to sacrifice GPU power. You dont need an SSD, and I would personally rather have more GPU power. If you dont feel the same thats fine, we can add one, no issue.
https://linustechtips.com/topic/366524-build-help/#findComment-4964702
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($179.95 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($61.98 @ Newegg)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($53.99 @ NCIX US)
Storage: Mushkin ECO2 120GB 2.5"; Solid State Drive  ($49.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5"; 7200RPM Internal Hard Drive  ($48.75 @ OutletPC)
Video Card: Gigabyte Radeon R9 285 2GB WINDFORCE 2X Video Card  ($162.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($87.49 @ OutletPC)
Monitor: Acer H226HQLbid 60Hz 21.5"; Monitor  ($126.99 @ Amazon)
Total: $988.09
Generated by PCPartPicker 2015-05-14 14:57 EDT-0400
https://linustechtips.com/topic/366524-build-help/#findComment-4964860
