Power wattage build problem.
Solved by Sakkura,
The "requirements" for graphics cards are exaggerated to account for many bad power supplies being unable to deliver their rated wattage, as well as for the varying configurations (the GPU makers have to assume the most power-hungry CPU etc).
For your current configuration, a 450W power supply would be a fine choice. Lower than that rarely really saves you any money. Going 500-550W would give you more room for upgrades though.
