I think that's a Lollipop thing. If I'm not mistaken the only way to solve it is with root.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/365888-lg-g3-problem/#findComment-4956171
I can.
You have to chose something though.It pops up when you try to do it but you can't. ( you need to choose the ext SD card)
Using 3.2.5.1 version.
(ES explorer)
https://linustechtips.com/topic/365888-lg-g3-problem/#findComment-4956242
