I am looking for a new case for my ATX motherboard, that is high quality, under $200, and has room for furture watercooling, and for now room for a radiator that is connected to a Corsair CPU water block. I would prefer a metal case because I feel those are the most sturdy, and I would also hope that the case has some kind of methodology used to dampen sound within the case...
https://linustechtips.com/topic/365618-quality-case-brands/
The best quality I've seen - Fractal Design r4\r5 (but r5 is a bit ugly with this modular top).
https://linustechtips.com/topic/365618-quality-case-brands/#findComment-4952456
Fractal Design Define R5 or Fractal Design Define S. I personally ordered the Define S for the immense water-cooling features that I will be using later on for my custom loop.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/365618-quality-case-brands/#findComment-4952460
I LOVE THE FRACTAL DESIGN DEFINE S, however I dislike how the Define S does not have the opening front panel and wont allow me to have any disk drives.
https://linustechtips.com/topic/365618-quality-case-brands/#findComment-4952477
450d , Define r5/S.
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/365618-quality-case-brands/#findComment-4952489
True, but they were removed for a good cause, water cooling.
https://linustechtips.com/topic/365618-quality-case-brands/#findComment-4952497
