I just bought 3 new monitors 2 1080p monitors and 1 4K and am trying to connect them to my 780ti, which has 2 dvi, 1 hdmi and 1 displayport. The new monitors don't have any DVI inputs only hdmi and displayport. Can i daisy chain all 3 over displayport and still get 60hz on my 4k? if i cant what's the best way to connect them? Would it be 1 through hdmi, buy a dvi to hdmi adapter to connect the other one and run the 4K of the display port.
https://linustechtips.com/topic/365477-help-with-displayport-daisy-chaining/
use the 2 dvi and 1 dp. the 1dp on the 4k monitor, then buy 2 DVI-DP and use them on the other monitors.
I don't think a not 2.0 dp can do 4k 60 while 1080p 60 x2
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
spam
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
No, 4K 60Hz will require the whole DisplayPort connection, there isn't enough data bandwidth for more. Use DP for the 4K display and HDMI and a DVI-to-HDMI for the other two.
