Hello, I just bought The Witcher 2 on a steam sale, and after installing it and running it, I get 40-45 fps. This would not be a problem if my PC was built in 2011, but I'm running a Sapphire r9 290 Tri-X with a AMD fx-6300 processor. The settings are Ultra with Ubersampling turned off. I have tried using the GPU driver config for the game, but i still get 40 fps.  What is interesting though, is that I still get the same framerates with low settings. Can someone please help me config this?
https://linustechtips.com/topic/365438-witcher-2-problems/
Dat bottleneck. Have you tried to overclocking your CPU?
https://linustechtips.com/topic/365438-witcher-2-problems/#findComment-4950275
 Either overclock your cpu or buy an i5 and watch your frames almost double. Witcher 2 is very cpu dependent.  :P
https://linustechtips.com/topic/365438-witcher-2-problems/#findComment-4950340
With my configuration i only get 60 - 70 fps , its a pretty demanding game. But Abdul is right maybe with an oc ull get the all the juice from the 290x.
xCPUx // 4790k 4.7ghz @ 1.32v \\ xMOBAx // Saberthooth Mark 1 \\  xGPUx  // Gtx 970 G1 gaming \\
xStoragex // Samsung 850 evo (128gb) and 1tb WD black \\ xCpuCoolerx // H100i \\ xCasex // h440 White\\ xKeyboardx // Blackwidow Ultimate stealth \\ xMousex // Tt Theron \\
https://linustechtips.com/topic/365438-witcher-2-problems/#findComment-4950370
