So this does not happen all the time...but sometimes like now i get an electric shock when I touch the usb drives on the case, so out of curiosity I touch the fins on the top mounted radiator as well and I get an electric shock too. I have a multiplug with earthing. I also have surge protection. Is this a problem with the wiring in the usb or the setup is wrong? According to the local electrician the setup is correct.
https://linustechtips.com/topic/365175-earthing-problems/
No its fine. Te shock goes through the xase down to the ground. Its ment for that. Otherwise you would have kwpt the charge on you
https://linustechtips.com/topic/365175-earthing-problems/#findComment-4946517
But the problem is whenever this happens, the cpu temperatures increase. Is that a coincidence?
It probably is. Try recreatin yhe events in a somewhat controled state. When nothing is running and the voltage is stable. Id do it at least 3 times.
https://linustechtips.com/topic/365175-earthing-problems/#findComment-4946697
