! HELP !
Go to solution Solved by ZenoEdits,
well i guess thats it solved. Long story shot , dont cheap out on a psu and if it seems to good to be true it probably is thanks all you guys i appreciate the fast responses
im running :
Nvidia GTX 970
16 RAM
2 HDD
1 SSD
AMD FX 8350 8 CORE
500W PSU
WINDOWS 7
and for some reason whenever i run a game , benchmark , or evan my editing software my pc just shuts down and i have to turn the switch on the psu off and on to then power me pc back on and i dont know why.
any help is appreciated.
https://linustechtips.com/topic/365127-help/
What are your temperatures? Please be specific with your power supply.
https://linustechtips.com/topic/365127-help/#findComment-4945886
idel temps are :
CPU : 14 - 17 digrees
GPU : 41 - 43 digrees
i cant find the heavy load temps cause my pc just shuts down before i can check
my psu isnt the best by any standard but its all i have for the next 2 weeks :
PSU : http://www.amazon.co.uk/STORM-SILENT-POWER-SUPPLY-MOLEX/dp/B00EALDJ3U
https://linustechtips.com/topic/365127-help/#findComment-4945898
idel temps are :
Your CPU is not likely running at that temperature. I think your power supply is shutting itself down.
https://linustechtips.com/topic/365127-help/#findComment-4945904
When you do nothing, will it shuts off?
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/365127-help/#findComment-4945905
heres the weird thing i can browse the internet , skype and play minecraft for hours without issus but asoon as its something intensive its shuts down
Try stress testing your PC, see what goes wrong.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/365127-help/#findComment-4945912
i havent a clue what that means xD
ik it sounds low for a cpu but i have a coolermaster 212 hydro cooler with 2 corsair af120 fans strapped to it and 3 case fans
https://linustechtips.com/topic/365127-help/#findComment-4945918
what i did was i powered up with my psu and powered my gpu with a differant psu and it worked fine , was able to benchmark and play games and now i cant evan do that
Sketchy power supply. Replace it imidiately. A cheap and good one is this http://www.amazon.co.uk/EVGA-500B-BRONZE-Power-Supply/dp/B00DZ6R9GE/ref=sr_1_2?s=computers&ie=UTF8&qid=1431427919&sr=1-2&keywords=evga+500w
https://linustechtips.com/topic/365127-help/#findComment-4945948
i was looking at http://www.cclonline.com/product/143877/AI-700W/Power-Supplies/Aerocool-Integrator-700W-PSU/PSU0676/because i thought my psu wattage was too low but now i know its not ill more then likely buy the one u posted.
https://linustechtips.com/topic/365127-help/#findComment-4945952
Try using a power supply from a reliable brand
eg Corsair, seasonic , NZXT , etc
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
https://linustechtips.com/topic/365127-help/#findComment-4945956
Pushing your parts, putting everything in 100% load.
But I think it's the PSU as well, like the others have said.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/365127-help/#findComment-4945964
yh so is it safe to use my pc and just boot it back up every time or shall i just leave it off for now untill i get my psu ?
Just watch this then
https://linustechtips.com/topic/365127-help/#findComment-4945973
You should never cheap out on your power supply, its basically the heart of your PC.
https://linustechtips.com/topic/365127-help/#findComment-4945980
i never paid for it i got it for free of a mate , but ima just unplug my psu and call it a day for a few weeks untill i get a new psu , cant afford all new hardware cause the psu has broke them xD
https://linustechtips.com/topic/365127-help/#findComment-4945999
`Good idea.
https://linustechtips.com/topic/365127-help/#findComment-4946003
