Hi, i am wondering what would you guys advise for a build guide/video for a PC build with these parts. This is my first build and am just looking for some advise.
Also, if this is in the wrong section, im am very sorry.
Updated:  the new- non broken pcpartpicker link   http://pcpartpicker.com/p/qvZvFT
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/364889-a-little-help/
Hi, i am wondering what would you guys advise for a build guide/video for a PC build with these parts. http://pcpartpicker.com/p/TWgqJx This is my first build and am just looking for some advise.
You posted the wrong pcpartpicker link.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943003
Follow your topics so you get the replies. And as stated your link is broken.
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943028
Broken link m8
Actually it isn't, OP just accidentally put in a space at the end.
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943033
What is the PC going to be for? What is the Budget? Is everything in the list you have what you need?
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943040
Link is broken, no worries though, just put the permalink(although for me it says error 404). Please follow topics to receive notifications, as well as quoting the person you wish to talk to so that they will receive notifications as well.
Does not having a second parenthesis around something bother anyone else as much as it does me? (Like if this statement was missing a second side)
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943047
As I said it is not broken. OP accidentally put in a space at the end and that is an easy fix
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943089
alright, sorry about that guys, the link has been updated
Follow your topic and quote people so they know you have responded. So what is the PC for. What is the budget? Is everything you have in the list what you need?
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943116
the budget it 1.5k and i am trying to leave it the way it is so far.  im just looking for a video that would help with a build like this. (if you missed it, this is my first build)  and i could not find a build that involves a liquid cooler and a GTX 970 windforce.  that being said, i think its fairly similar and i could just try looking at 2 separate videos, but i would still like to hear what others have to say
-Made In Canada
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943178
http://pcpartpicker.com/p/MN9vFT
https://linustechtips.com/topic/364889-a-little-help/#findComment-4943597
