Hello everyone! I am in need of a smartphone! My budget is 150 to 200 USD.. My requirements are Two camera's with good quality, 4g compatibility, Able to run the game Hearthstone well, and at&t compatible.. I can use new or used as long as the used phone is unlocked.... thanks
Edited by Glenwing
Removed caps lock from title
https://linustechtips.com/topic/364641-smartphone-help/
Moto E LTE 2015?
https://linustechtips.com/topic/364641-smartphone-help/#findComment-4940069
I would look for a used LG G2 or an HTC One M7 if they cost around there, maybe a new Moto E LTE or the Alcatel OneTouch Idol 3 (doesn't come out until later this month) if you can't find the others.
https://linustechtips.com/topic/364641-smartphone-help/#findComment-4940075
i can highly recommend a used HTC One M7. if you can get a good deal on one you should definitely consider it!
it has good camera's front and back (ultra pixel technology) and depending on the model you get it is also 4G compatible!
https://linustechtips.com/topic/364641-smartphone-help/#findComment-4940185
