Hi all,
I have a problem with the accuracy of the temps that is being shown for my CPU.
As you can see HW monitor is displaying a high temp rating for my cpu but the gigabyte tool is displaying a different result.
What i have tried
Updating BIOS version from F8 - F9
Reinstalled my OS
Replaced CPU coolers from CM Seidon 120m to Noctua NH-D14
Cleaned the CPU with 90% alcohol and re-applied thermal paste
Tried Beta Drivers from AMD
Tried normal drivers from AMD
nothing worked.
My rig:
CPU: AMD A10 7850K
Mobo: Gigabyte G1 Sniper A88X
Ram: Gskill Sniper 2x4gig Kit 1600
Vcard: Sapphire R9 270x Dual X
PSU: Seasonic M12II 620 Modular
Case: CM Haf XM
Fans:
1x200mm intake front
2x200mm exhaust top
1x140mm exhaust rear
1x120mm hdd cage
Ambient temp is ok as i have my room air conditioned
Any suggestions as to what else I can do?
https://linustechtips.com/topic/364492-temperatures-not-the-same/
Hi all,
What i have tried
Reinstalled my OS
nothing worked.
My rig:
CPU: AMD A10 7850K
Case: CM Haf XM
Fans:
2x200mm exhaust top
1x120mm hdd cage
The HWMonitor is better then the other program you have. It gives more Real-Time results faster, while it seems like the gigabyte give an estimate. that or it's not giving anything at all.
plus it makes more sense for your CPU is at 69C then at like 30C
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
