Help with Java?
Solved by Neil,
Could someone move this to the programming subforum?
@op: wrap your code In code tags so it gets highlighted.
In java , you cannot have two main classes in the same file (normally).
You will want to create a new class (file) in Eclipse.
Also, your terminology is a bit... Odd. You're not "making a letter equal" something. You're initializing a variable to a value.
Featured Topics
amir2927 ·
Posted in CPUs, Motherboards, and Memory1 -
realfireguy ·
Posted in Graphics Cards0 -
Winterlight ·
Posted in Phones and Tablets1 -
4
ineedhelp.2145 ·
Posted in General Discussion0 -
1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
