Little help needed in "debugging" build
By
giordi
in Troubleshooting
in Troubleshooting
Solved by CalumGiff,
Hi yeah I bought one , should arrive today, sorry I called it tester but is actually an analog multimeter, so you think that the PSU might actually be the problem?
From the information you have given then yes, but that still doesn't necessarily mean it is the problem. Deff worth a look though
Ryanwake ·
Posted in General Discussion1 -
1
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases0 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning16
play_circle_filled
Latest From ShortCircuit:
