Mic problem.
Go to solution Solved by ShearMe,
Ye sry. I just found that too. Did not realize it was on the saffire itself. My bad.
I just fixed it I think. I turned phantom power on and switched channels and that seemed to fin it. Thanks!
Mark solved pl0x
Ok so I have an Audio Technica recording mic(not sure which model). Hooked up to a Saffire pro 10. Now about 2 months ago I was using this setup for steam chat and skype etc. I have not used it much since then. Today I wanted to use it so I turned every thing on but now when I listen to it or record something with it all I hear is static. Loud static.
Any help? Let me know if I need to find more specs or anything.
Thx 4 ur time.
Tech
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/36306-mic-problem/
https://linustechtips.com/topic/36306-mic-problem/#findComment-465850
I have tried lowering input levels and output levels to no avail.
https://linustechtips.com/topic/36306-mic-problem/#findComment-465881
do u have phantom power enabled if not that could explain it
I do not think so. Where would I go to check?
https://linustechtips.com/topic/36306-mic-problem/#findComment-465903
https://linustechtips.com/topic/36306-mic-problem/#findComment-465952
Mark solved pl0x
https://linustechtips.com/topic/36306-mic-problem/#findComment-468907
