Heyyo,
Any motherboard will suffice. Gigabyte boards are among the most favored for hackintosh builds. Just load into your UEFI and set your storage drive controllers to AHCI and you're set. ;)
Yes, you can use hackintosh without buying a discrete GPU.
Whenever I've done hackintosh? I've always used Tony Mac's setup. Works fantastic.
http://www.tonymacx86.com/
Heyyo,
My PC Build: https://pcpartpicker.com/b/sNPscf
My Android Phone: Exodus Android on my OnePlus One 64bit in Sandstone Black in a Ringke Fusion clear & slim protective case
Heyyo,
Ok great thanks :) Any complete and specific guide?  :rolleyes:  TIA
Heyyo,
http://www.tonymacx86.com/installation/
All kinds of guides amigo. ;)
TonyMac is the legal method of doing it. I won't link the illegal ones for Yosemite though. Don't wanna get banned. :P
Heyyo,
I've had great success with Gigabyte boards, never managed to get an Asus board working (only tried one board though) but if you head to Tony Mac linked above and click the buyers guide then motherboards and it will give you a list of supported boards.
GPU go Nvidia, AMD can cause issues (I think most issues are resolved now). Intel onboard also work great.
Main Rig:-
Server:-
