Customizing FN keys on Ducky Zero.
I was planning to get the Ducky Zero but the Fn Keys only has Windows Key lock and key roll-over switch. Is there a way to add media controls using those Fn keys?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/3628-customizing-fn-keys-on-ducky-zero/
If nothing else, you can try looking at AutoHotKey to set certain keystrokes as media functions. I've been doing that with my keyboard, and I have the script starting with Windows running in the background. It's unobtrusive and a nice last resort if you can't find a better way :D
does it use the fn key though? and does it slow down startup time?
The script doesn't slow down my startup at all, but unfortunately I'm not using the fn key in my setup. I doubt that you can use the fn key for macros in AutoHotKey, but then again I've never tried. Sorry!
oh ok thks for your help!
