Best CPU solution for a GPU upgrade
Solved by ADZ_123_!"£,
Hello everyone
I'm saving up for an R9 270, and I currently have an AMD A10-6800K. I've read and seen people say that it was best to get a standalone processor for a GPU upgrade. and others say just disable the onboard graphics. I'm pretty sure the CPU portion of the A10-6800K is equivalent to the X4 760K.
Should I just disable my onboard graphics on my APU? Or should I get a standalone processor along with the GPU?
I would really upgrade to anything on the intel lga 1150 platform which you can afford whether tat is a I3 a I5 or a pentium any of those cpus wont be a problem for a 270X.
