Hey guys, i have help my sister build her new computer. we have used some of my old parts to save some money on the build.
Pc Specs:
CPU - AMD FX8350
Ram - 4GB corsair vengeance
GPU - Nvidia GTX 550 it
Power supply - coolermaster (for got the rest) 500 watt
Motherboard - msi 990fxa-gd65
After building the PC, the computer is REALLY slow. When lunching a program like league for example, it take a very long time to load the launcher and it also takes a very lone time to  load in to the game.
The Other problem i have with the computer is, when you shut down or reset the computer , then turn it on it will automatically shut down with out warning. it keep doing that until you unplug the computer and hold the power button for a few second. All this has never happened before. i have search many forms for help, and many have said to test the hard drive (which i have not done yet)
Thanks!  ^_^
https://linustechtips.com/topic/362426-computer-running-alot-slower/
1. Defrag if you have a hdd.
2. uninstall un-needed programs.
3. run a scan with malwarebytes anti-malware
4. remove startup programs that you don't need.
What antivirus do you use?
Pc Specs:
CPU - AMD FX8350
Thanks!  ^_^
sounds like a drive issue to me. Defrag/ make sure trim is running. What drive did you put in there? Check its smart values and stuff. Also do a antivirus scan and reinstall windows.
EDIT: Welll it seems like i got ninja'd
@DatGuyFantasy Defrag the hard drive, run ccleaner, scan for malware, and holy shit 4GB of RAM? How do you live?
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
