Hello, I have jus upgraded from a amd 8320 that was overclocked to 4.7 ghz and would hit a max temp of 40c with prime95 to a intel 4790k that just idling hits 64c. I also have sli 780's and they are 23c. I have two 480 rads, 1 360 rad, 1 240 rad, and 1 120 rad. The only thing that has changed in the loop is the cpu, motherboard, and the cpu block. These temps are crazy with my system so any help will be much appreciated!!!
https://linustechtips.com/topic/362298-i7-4790k-high-temps/
maybe try re-seating the cpu block and re-applying thermal paste?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/362298-i7-4790k-high-temps/#findComment-4910845
Bad thermal compound maybe? Or if you are sure that it's not the problem try (if possible) testing with the old CPU block. Just so you can get some idea where the problem is. Is the 4790k at stock settings?
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning.
https://linustechtips.com/topic/362298-i7-4790k-high-temps/#findComment-4910860
i rest the block and found one of the stands had come loose temps went down but i am still in the 40's jus idling. That is what i was getting under max load on my old amd. I don't believe it is the paste. I cant check the old block on this build because it is intel now the old build was amd. yes it is not overclocked it is at factory settings.
https://linustechtips.com/topic/362298-i7-4790k-high-temps/#findComment-4910949
