CPU Help
Go to solution Solved by Atmos,
If you're not cooling, just get a cheap air unit. Water cooling is generally only for high overclocking. With a case that big you can easily fit a hyper 212 evo which is a legendary cooler.
And as for the ram, you won't need more case fans what you have is fine. And as for the GPU sli is for Nvidia, crossfire is for amd. If you plan to upgrade GPU wise I would really rec. Not getting a second 270x,but getting something like a 280x or cheap 290,that way you don't have to deal with cfx scaling and the occasional bug.
Hi all, this is my first post so sorry if I get it wrong,
I recently just after Christmas built my first computer with the specs,
AMD 6300 six core 3.5ghz
R9 270X sapphire
HyperX Beast 2133 dual channel 2x4gb kit
NZXT phantom 410 case with the 3 stock fans
Corsair CX600W PSU
Asus M5A99X EVO 2.0
2TB HDD
Optical drive
TP Connect wireless card
I am currently using the stock heat sink and up until now it's been ok with idle temps of 47c, but recently the fans have been running at max on idle and when I have been running light games of tf2 it has been turning off randomly. So I checked the temps while on boot up after about the 10th cut out in a month and the temps were at 67c, I thought that that was hot, it currently sits next to my desk with about 2" on each side and good airflow. My room temps are the normal, so I have no Idea why it's cutting out as it's not a power cut and can only think that it's getting too hot. Any suggestions? And I'm planning in getting a new heat-sink but can't find one that's not too big, looks good and is reasonably priced, I won't be over clocking. I was thinking a corsair water cooling all in one unit would be good what do you think. I'm so thankful if you can help, thanks a lot. And lastly planning on adding a second of the same kit of ram and another graphics card in sli, will I be needing more case fans for this?
NeonJam
https://linustechtips.com/topic/362191-cpu-help/
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/362191-cpu-help/#findComment-4909358
