Need an ssd
Go to solution Solved by Wufflez,
im probably only looking ssd for OS mainly dont need to replace the hdd as i would just format the one whit os in it and start using it as storage like my other hdd is doing
120GB Samsung 850 EVO. There's no competition for the price/performance with this SSD.
So i need ssd nothing special im not really picky about speeds so what cheaps ssd that have good life cycle there are cause my 2 hdd both are starting to die as they are 10+ years old and i started noticing this week that even opening program files took time and its driving me nuts.
https://linustechtips.com/topic/361956-need-an-ssd/
how much capacity do you want if you're replacing HDDs with them
https://linustechtips.com/topic/361956-need-an-ssd/#findComment-4906282
Samsung 850 EVO is your best SSD right now without spending too much. Either 120GB for OS and programs, or 256GB if you need some playroom. I'd get an OS drive and leave it at that personally, though.
yeah that's what im doing i dont really mind long loading screens in games but when my os starts to become slow i will go insane
https://linustechtips.com/topic/361956-need-an-ssd/#findComment-4906287
im probably only looking ssd for OS mainly dont need to replace the hdd as i would just format the one whit os in it and start using it as storage like my other hdd is doing so i think 120GB  is the best as i dont got alot of money anyways unless 256GB is only 10-20€ more then i will buy it
https://linustechtips.com/topic/361956-need-an-ssd/#findComment-4906291
https://linustechtips.com/topic/361956-need-an-ssd/#findComment-4906300
