Monitor problem
MrSushi
Hello.
My monitor works normally i can reach monitors menu but it doesnt display my desktop even tho its connected through display port. My monitor is LG 34UM95-P. Everything worked normally until now.
This happened before monitor stopped displaying desktop:
Can anyone please help me with this problem?
Thank you for replying.
You know that those ultrawide monitors are practically two monitors right next to each other. So it looks like your cable is screwed up (try changing it to a different one). It's showing menu correctly so I don't think it's the display. You can also try different display port on your GPU (if you have spare one).
