So by 2 intake fans you mean pushing cool air in, right?
yes, that is correct. There are plenty on fan spots with filter's on this case so you should be fine with dust as long as you clean it. I like to have air being pushed over the pch and other components, this can higher overall temps and make more dust but, i prefer it. Honestly temps wont be very different if you make them all intake or exhaust.
Temps wont decrease much by adding more fans, did you want less noise? You can take off the panels to see what temps are, this would be the lowest youll get without alot of effort. It may not be worth it to add more fans.
okay
