So I have an Asus VG248QE and love it, but there is one problem. I am using an HDMI cable to use the monitor from my PC. When I turn VSync on, I get locked at 60 frames. My monitor is locked at a 60 refresh rate currently. The in game settings all end at 1920x1080 60Hz. Any ideas on how I can fix this, or does HDMI lock at 60? I am also going to purchase a DisplayPort cable soon.
https://linustechtips.com/topic/360323-vg248qe-help/
Go into your monitor settings and set the monitor to 144hz, you should find the setting in the nvidia control panel.
https://linustechtips.com/topic/360323-vg248qe-help/#findComment-4885298
HDMI is capable of only 60Hz.
Use DVI (the cable that came with the monitor) or displayport.
https://linustechtips.com/topic/360323-vg248qe-help/#findComment-4885315
