I soldered some red 12volt leds together and ive ran them inside and udner my h440, they are currently powered by molex and so are not able to be turned on and off unless i shut my PC down. I found this
http://www.amazon.co.uk/dp/B0046Y1622/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=3PS2VBQTNJHN0&coliid=IULF3IMP60XQ
and i was thinking of attaching the rest of my leds to the strip and using that as a controller?
Will it work?
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/358946-just-a-simple-led-controller-question/
Will it work?
For a 12V LED strip that will unfortunately not work, those are 3.3V LED's and with my guess are wired in parallel that way. I would suggest soldering in an on/off switch or simple controller to control your LEDs.
http://www.amazon.com/Remote-Controller-Single-Wireless-Control/dp/B00MHKCTLE/ref=sr_1_1?ie=UTF8&qid=1430588234&sr=8-1&
This would work CalumGiff just need to find one on a UK site.
Here we go try something like this - http://www.amazon.co.uk/JnDee-Wireless-Remote-Controller-dimmable/dp/B00CXS2GFO
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
