I started to overclock my GTX 960 and I first ran he stock settings in Heaven and got 1276 or something.
and the more i overclocked thee lower the score...
Why is this happening??????
Please help
Thanks
My PC Specs: CPU: Core i5 4590 @ stock speeds, GPU: RX 480 8GB, RAM: 16GB DDR3 @1600mhz
Case: Zalman ZM-T4,Motherboard: GigaByte GA-H81M-S2H LGA 1150, HDD/SSD: 2TB Seagate Expansion drive, 1TB Samsung Portable HDD, 160gb Intel SSD, PSU: 550w corsair cxm
:lol:  :lol:  :lol:  :lol:  :lol:  :lol:
https://linustechtips.com/topic/358807-heaven-benchmark-and-overclocking/
Throttling? How's the load on the gpu while you're benchmarking?
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
How do I check??
the temperature only goes up to 58 degrees Celcius
How do I check??
Check on Afterburner's monitor.
Is it GPU usage??
Is it GPU usage??
Yep.
Yep.
91-99%
Yep.
Results were 1233
91-99%
Eh, seems okay then.
Did you try rebooting, setting the clocks and then benchmark it?
'Cause the only thing you'd see if your clocks were too high for the core/vram would be artifacts or a black screen, never a reduction in performance unless if it were caused by throttling which doesn't seem to be.
That seemed to work :)
