I have the asus gtx 780 with their cooler, and i am planning on getting the bitfenix phenom m.
I ask because i recentley got the corsair 240, and the length of my gpu was just fine, but it was to wide so i couldn't close the sidepanel... And since casemakers only say how long, but not how wide your gpu can be, i was wondering if you guys know if it will fit.
so in short will my 780 fit in the phenom m?
btw tomme means inches (my gpu dimensions)
https://linustechtips.com/topic/358667-will-my-gpu-fit/
I have never had the width of a GPU be a problem.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/358667-will-my-gpu-fit/#findComment-4866677
It will fit.
CPU: Intel i7-4790K @ 4.7GHz --- RAM: Lenovo 1600MHz 16GB --- MOBO: Gigabyte Z97-G7 --- GPU: EVGA GTX 970 FTW ACX 2.0+--- PSU: Corsair CX600 --- Case: Corsair Air 540 --- Cooler: NZXT Kraken X61 --- OS: Windows 8.1 --- Monitor: 24" AOC G2460P + Dell 19" --- Mouse: Logitech MX Perfromance --- Keyboard: Corsair K70 (Cherry MX Brown) --- Audio: Sennheiser HD558
Don't buy a GTX 980, it's overpriced! Buy 2 GTX 970s or 2 R9 290s intstead (the R9 290s would even be cheaper)
https://linustechtips.com/topic/358667-will-my-gpu-fit/#findComment-4866686
u sure?
Well yes. If you put the two parts in PCPartPicker then it comes up with no errors, also, maths...
https://linustechtips.com/topic/358667-will-my-gpu-fit/#findComment-4866713
It has the room to fit length wise, and I believe width wise, however your PSU will limit GPU length.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/358667-will-my-gpu-fit/#findComment-4866776
