Ok, this is for the very experienced.  I haven't seen it done before.  I'd just like to know if you think it is possible.  I'd try it on old hardware before attempting it on a new rig.  For ultimate cable management I'd like to reverse the pinouts for the mobo and cpu power and solder to the back with a disconnect at the power supply or behind the mobo tray.  Magic invisible power!  It would require a hole in the mobo tray behind each power point.  That's easy with a dremmel.  What do you think?
Laws only govern the honest.
https://linustechtips.com/topic/35806-invisible-power/
