So, I'm looking for a remote control for my HTPC. Can anyone recommend a super cheap, basic, wireless keyboard and mouse, as well as a (super cheap, basic, wireless) remote control? And maybe an arcade style joystick+buttons for stuff like Pac man?
Just a guy who peaked at building back in the days of the GTX 980. If you see me here, assume i have technical knowledge akin to a committed hobbyist builder back then. If something's changed, you'll need to tell me(nicely plz). I'm probably asking for help with the modern build scene since I have no clue what's going on.
https://linustechtips.com/topic/357863-remote-control/
https://linustechtips.com/topic/357863-remote-control/#findComment-4856087
This is probably the cheapest all-in-one solution you can find without going to shady brands
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/357863-remote-control/#findComment-4856109
Yeah logitech is a solid brand.
https://linustechtips.com/topic/357863-remote-control/#findComment-4856114
Yeah, might go for this.
https://linustechtips.com/topic/357863-remote-control/#findComment-4856122
I use the rii mini :) there are a few versions including some more joystick looking ones
https://linustechtips.com/topic/357863-remote-control/#findComment-4856152
https://linustechtips.com/topic/357863-remote-control/#findComment-4856225
Unified Remote: basic mouse and keyboard functionality right out of the box on your phone, XBMC support with the paid app
http://lifehacker.com/how-to-control-anything-on-your-pc-with-your-android-ph-1500063190
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/357863-remote-control/#findComment-4861574
