Attempted? Yes, Failed miserably? Also yes, went and bought a pi a while back 2014 ish with no Idea what I was doing, I watched some video guide and thought I could handle, I just failed miserably. I believe I even fried the circut. Now however I'd like to think ive learned enough to change the outcome
My article on subscription based services and why they are the way forward http://linustechtips.com/main/topic/382625-what-the-future-holds/
https://linustechtips.com/topic/357557-raspberry-pi-radio/#findComment-4852773
how did you get the sd card to run propperly? (mine crapped out on me just now amd i cant re write it)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/357557-raspberry-pi-radio/#findComment-4855329
I didn't manage to, as I said the first time run killed the pi... However I did make sure it was working before I used it for the attempt.... I put it in my laptop to see if it worked and it did
https://linustechtips.com/topic/357557-raspberry-pi-radio/#findComment-4859333
