Need just a bit of help
k1llampt
My friend has been having an issue with his sound and i cant figure it out, he has a sabertooth 990fx r2.0 motherboard which has the realtek alc 892 driver, we uninstalled and reinstalled both from his motherboard driver disk and a direct download as well, hes checked the back i/o and made sure the headset was plugged in correctly as well as trying another headset. we also tried the front panel. nothing is registering when he plugs it in, any advice?
Archangel(z11 Build) CPU: Ryzen 7 1700 @ 4.0 GPU: 2x Sapphire R9 290x RAM: 16GB GSkill Ripjaws V 2800 Mobo: ASRock X370 Killer SLI/AC Power Supply: Cougar CMX1000 Case: Zalman Z11 Plus HF1 Storage: 120GB Intel 520 SSD, 1TB WD Blue
Reptile(Dual G34) CPU: 2x Opteron 6172 RAM: 32GB DDR3 1866 ECC Mobo: Super Micro H8DGU-F Power Supply: Seasonic SS-660XP2 Case: Phanteks Enthoo Pro Storage: Hitachi Ultrastar 7k300 3TB
White Knight:(wife's build) CPU: A10-6800k GPU: MSI 7970 Lightning GHz BE RAM: 8GB HyperX Fury White 1866 Mobo: MSI A88x-g43 Power Supply: Seasonic M12II 520 Case: TT Commander Snow Edition Storage:1TB WD Blue
Is onboard audio disabled in the bios/uefi
X79A GD65 (8D), 3820, 7770, 16GB (1600Mhz cas9), 850watt(ocz zx), storm trooper, h100, xonar xense, sp2500, pc350, asus PA248Q LG 22'' ips, razor black-widow ultimate 2013, 120GB intel 520 series 128GB crucial M4 2*3TB barracuda 2*1TB barracuda 2TB Hitachi
This might not work but try this.
Right click on the little speaker next to the time/date, select Playback Devices.
Right click on Realtek High Def Audio and select Set as Default Device.
My friend has been having an issue with his sound and i cant figure it out' date=' he has a sabertooth 990fx r2.0 motherboard which has the realtek alc 892 driver, we uninstalled and reinstalled both from his motherboard driver disk and a direct download as well, hes checked the back i/o and made sure the headset was plugged in correctly as well as trying another headset. we also tried the front panel. nothing is registering when he plugs it in, any advice?[/quote']
is this a new build? if so i would check the motherboard and make sure the sound pins on the motherboard for audio is properly seated. (had them pop out once on my old motherboard when i accidently hit the case with my leg.)
i5-3570k @ 4.5ghz at 1.2v (5ghz @ 1.4v max stable) , Radeon HD 7850 @ 1200/1450 Clocks http://www.techpowerup.com/gpuz/kasmr/, AsRock Z75 Pro3 Mobo, 8gb of 1333mhz ram @ 1600-8-9-8-16.
this is a build that has been running for about 3 months. the audio is not disabled , but its still not picking anything up, he emailed asus and they believe its a bad sound card possibly even the controller.
from what i read, it sounds like a bad controller
check the device manager to see if realtek sound is there.
if it's not there I'd probably say either RMA the motherboard or buy a pci(e) sound card.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
  • 2 weeks later...
By the way we did fix the issue, it was a bad controller, and he didnt have the time to RMA, he couldnt have the down time. We ended up buying a dedicated sound card. thanks for the help anyways guys!
