Hello fellow gamers.  I am currently in the progress of making a list of the items I want in my first build, and I am looking to build a mid to high end build.  I am thinking of using an i5 4690K with a Asus z79-AR mobo and a nvidia gtx 970.  I have consistently see people talk about how the mobo has little to no influence on performance, hence the cheaper mobo.  Is the 4690K suitable for a gtx 970?
thanks
https://linustechtips.com/topic/357074-correct-cpu-help-needed/
thanks
Yes. /thread
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/357074-correct-cpu-help-needed/#findComment-4845881
Sorry, silly question:  should I be concerned about bottlenecks?  For gaming purposes, does the 4690K perform on average the same as the 4790K?  I have no intention of doing any video or editing work.
thanks
According to benchmark videos on YouTube, the 4790 offers very little advantage over the 4690 and not on every game. It's not cost effective because of the price difference.
https://linustechtips.com/topic/357074-correct-cpu-help-needed/#findComment-4846162
thanks
The 4690k won't bottleneck Quad TitanXs.
Yes, they do. Not many games use more than 4 cores.
https://linustechtips.com/topic/357074-correct-cpu-help-needed/#findComment-4846187
i have a 4690k and a 970 and it bottlenecks like crazy!!!!
seriously the 4690k won't bottleneck a single gpu for the foreseeable future. hell the i5 2500k is still going strong :P
while a motherboard doesn't directly impact performance, it plays a major role in stability and overclocking. I'd recommend the z97-A if you can fit it into your budget without sacrificing anything else. it is a great board and has good overclocking potential (plus overclocking on it is pretty easy), but only if you can fit it in without sacrificing anything performance related. (i'm assuming you meant z97-ar?)
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/357074-correct-cpu-help-needed/#findComment-4846263
good luck getting any game to actually use 4 titans....
if the titans were fully used tho..im sure a 4690 would be the bottleneck
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/357074-correct-cpu-help-needed/#findComment-4846275
Perfect scaling? Probably.
https://linustechtips.com/topic/357074-correct-cpu-help-needed/#findComment-4846377
