Ok guys this is whats happing. I set up a pc just for my audio so my mic is hooked up to that pc with all my voice changers auto tuners and so on. I have it comming to my line in to my main pc the problem im having is. I can hear my self twice when recording. Things i have checked on both pcs in sound options make sure that the box isnt check for listen to self and also in realteak i have the play back option off as well. Can anyone help. the reason i set it up this way is its a pain to half to alt tab just to change settings in games i wanted a deticated pc just for this.
CPU:I7-4790K @ 4.8ghz MOTHERBOARD:MSI-Z97-G45 Ram:G-SKILL SNIPER 8GB 1866 GPU:Msi GTX 970 4G COOLER:PHANTEK PH TC14PE BK 3 FAN CONFIG PSU:Roswell Lightning 1300W HDD: 1TB WD, 2TB SEGATE Mushkin 120GB SSD CASE:COOLER MASTER HAF 922
https://linustechtips.com/topic/356618-mic-issue/
might be an audio delay caused from processing the audio from one pc and sending it to the next
https://linustechtips.com/topic/356618-mic-issue/#findComment-4840347
what is funny is it only happens with the mic all other audio is fine and don hear it twice this is what confuses me. I can hear my self twice only with my auto tune now so i think it has something to do with that software.
https://linustechtips.com/topic/356618-mic-issue/#findComment-4842987
