Looking for this or something similar. But I can find nothing
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998086
I would probably try ebay, because on the website it says Discontinued ... I honestly didn't even know those existed.
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/35630-help-finding-a-product/#findComment-456180
https://linustechtips.com/topic/35630-help-finding-a-product/#findComment-456217
https://linustechtips.com/topic/35630-help-finding-a-product/#findComment-456235
