Line in audio recording solution?
Solved by Prastupok,
Upon further investigation it seems they made multiple versions of the AM 442D and mine is without USB, sadly. I would have personally called it like, the 442.5 or 443 or something, but my mistake, and sorry, but we are back to square one.
Then as I said, you will need an interface. Something like this would be what I would get: http://www.sweetwater.com/store/detail/UltraLiteAVB
It's a little pricey, but has a lot of great features and can be expanded further in the future.
